deckedoutmp5 said:that is the smallest line return ive seen. wild.
(werd) I wonder what that will do for oil pressure? Make sure to check your intake pipes periodically for oil.
LinuxRacr said:(werd) I wonder what that will do for oil pressure? Make sure to check your intake pipes periodically for oil.
Little Beavis said:I think it just looks small in the picture (those are "big" ends), I'm sure it is a -10 hose and fittings. . .so it is probably the same size as yours.
Since the turbo is fed by a -4 oil line, it is more that big enough to not cause any problems. . .don't scare the poor guy.
LinuxRacr said:I used the Permatex Red Thread Lock
deckedoutmp5 said:just for comparison here is mine... i would never run a line that small...
duMb KeoLa said:how long is that oil return line? looks perfect but i believe my return line is too long, it curves and curves and eventually ends at the oil pan...maybe thats why i smoke so much
