540James said:i have unichip installed, will disconnecting the battery to the car for "x" amount of minutes do anything to the map on the unichip? or will it be the same
JDM Sam said:No, it doesnt learn around the tune. It feels fresh b/c you erased the keep alive memory in the system and any bad driving conditions it may have recorded. If the PCM sensed it need to pull some timing it may have left that change. You can reset the PCM by turning the car off, key out, and switching the ECU power button off on the Unichip switch.
you should. it comes out of the PnP harness 3 switches. you got a used or incomplete unit then.540James said:i dont have any of the switches on the unichip, or the boost controller
