I am in the process of doing the very same project. There are only two bolts and one nut to remove, the front bolt, the rear bolt and nut that holds on the brake lines (12mm). The rear bolt seems to be pretty easy to remove, the whole bolt is inside the bushing, so rust is not an issue, one good pull and then ratchet it out. However the front bolt is another matter. The bolt head has easy access from underneath, but the inside of the bolt has a square nut that is enclosed by a weld shield like thing that is SUPPOSED to stop the nut from spinning while you unscrew the bolt and space is limited as this end of the arm is fortified to the side of body by a shield that limits access to nut end. In my case (Michigan) the first few cranks on the bolt head where tough, but I it was working out. Then it all came to a stop. The nut started to be able to spin inside that welded shield. I tried all sorts of things. What worked in the end, I broke off the shield (not easy) held the bolt with a pair of vise grips and cranked like H%LL to remove the bolt (car was only up on a ramp, I did not have a lot of leverage room. I got it off! Now all I need to do is find the trailing arm. It seems it is only a dealer part. And one side is more expensive than the other side.
