Renesis Rising
- 439 MSP Ebony Mica
is there any truth to this...i just heard of turbo kits for the renesis!! now im all confused...
Renesis Rising said:and my pockets say s*** godddaaaaaaaaaamn.....but all that increase in power also come with upgrading brakes and suspension to handle all that. so that even more money right?
Signal 2 said:I'm not an engineer, but IIRC, another major reason that the RENESIS doesn't respond well to turbos is due to the design of the ports. The exhaust does not have an unobstructed route to the turbo, and likewise the intake port aren't as direct into the combustion chamber as they were in the 13b or 13bREW. As I understand it, the design change helped to make the car more CARB compliant, and the higher compression rotors gave more NA power, but both made a turbo version more difficult. Add on the restriction caused by the turbos themselves, and there just isn't as big of a return.
Nothing to back this up, but personally I think before we see a factory turbo renesis, we'll see a three-rotor NA.
ghettobubba2001 said:(omg) anyone got an rx8 turbo kit on they're ride yet? i want to see flames![]()
Interesting. I stand corrected. I'd read somewhere about the concern for cats too, but not seen the figures you quote for the Greddy unit. If those are accurate for rwhp, that does seem like a good value. In every damn reveiw of the RX8 I see the authors LOVE the car, handling etc. but ding it on low-end grunt. That would definitely be one answer.KYLiquid said:the major factor against a new turbo rotary is emissions and catalytic converter life. New US regulations require that the cat in a new car last 8yrs/80k miles (i think thats right) and a big thing that kill cats are high EGT's and running rich, both of those are thigns that rotarys do.....so mazda would be on the hook replacing cats all the time (if they could even meet emissions) or run the car with so little boost there is no point.
The renesis can take to a tubo very well.
A stock NA 6port (6speed) RX8 makes about 180whp/130wtq
The same car with the greddy turbo kit, exhaust and x-interceptor ecu (tuned) makes 330whp/280wtq.........your almost doubling the power of the car,and your MORE than doubling the TQ....amazing!
Thats a 150whp/150wtq increase for about 5k in parts/tuning......not bad at all, I would say the renesis takes very well to turbo.....it has 6 intake ports, and the ports are larger than any other rotary made, and also the higher compression leads to more power.
The exhaust ports and location of the exhaust manifold make getting good flow OUT of the engine and placing a good size turbo difficult but not impossible.
The way the exhaust ports are is killing exhaust flow, not by a lot, but noticable, you could maby pickup 10-20 hp at redline with a better port design but thats not something we can really change......
Signal 2 said:Interesting. I stand corrected. I'd read somewhere about the concern for cats too, but not seen the figures you quote for the Greddy unit. If those are accurate for rwhp, that does seem like a good value. In every damn reveiw of the RX8 I see the authors LOVE the car, handling etc. but ding it on low-end grunt. That would definitely be one answer.
Captain KRM P5 said:i have read that many people have blown thier renesises (sp?) with the GReddy kit even when tuned religiously on the emanage, something where the emanage does not always work as prescribed?
ghettobubba2001 said:why would it be on race gas most kits are meant to run on premium - 93 so really why would they dyno that s*** with race gas.
ZoomZoomH said:*looks in pocket*
nope, no $5000 in here![]()
