i removed a windshield sticker from the car. I have removed all the adhesive and its not sticky anymore. the window is clean and clear when dry. however, when it rains, you can see the drops of water on the windshield form the outline on the window where the sticker used to be. its pretty interesting since you can't see anything when its dry and when its wet you can read and see what was there before. like i said, its not sticky and i can't really feel it with my fingers. how do i remove this so that the window is totally clear when its dry and when its wet?
i tried rubbing alcohol, spic and span proffesional, glass cleaners and vinegar/water solution - nothing helps.
