"I have a Speed 3 Grand Touring, so, yes, it is the turbocharged engine. The website recommends changing oil every 5,000 miles if conditions are not "severe" and every 7,500 if conditions are severe"
Check that again. You have that backwards. "Severe" conditions require more frequent change intervals.
"My personal philosophy is to change oil every 3,000 and use "Dino" oil rather than synthetic. The primary benefit from synthetics, if I can believe the technical bulletins I've read, is superior performance under high temperature conditions. It has other benefits, but high temps would argue for exclusive use of synthetics"
Yes, high temps is a primary benefit but longer change intervals is another benefit. If you change every 3k then dino should be fine. Synthetic oil would be overkill in your case.
"Changing every 3,000 vs 5,000 means an extra 13 oil changes over 100,000 miles, of ~ $500. I consider that cheap insurance"
That may be cheap to you but don't confuse it with insurance. Insurance will pay you for loss. If your engine craps out when following a 3k change interval the oil companies won't pay you a thin dime unless their product is proven to have caused the engine failure as was the case with Quaker State oil back in the 60's.
"I have a friend who owns a Porsche and insisted on following Porsche's 12,000 - 15,000 mile oil change intervals"
I've never heard of factory recommended intervals that long & I'm not doubting it but people forget there's also a time element involved. It's possible he put very little mileage on the car & it took him several years to put 12k miles on the engine, resulting in violation of the time restriction.
"Don't need to hear many stories like this one and the BMW owner who responded to this thread showing pictures of his engine internals gunked up after 7,500 mile intervals"
Don't believe everything you see posted on the internet. The BMW owner you referred to may have an agenda...
