Using a Acron 9145 Scanner, which does PID data, live engine data,
Driving around town I see, passing 2 banks I see their digital signs reading exactly 99deg, the ambient reading on the A/C system shows 100, and my scanner shows high a few deg about 103 for the variable 'Outside temperature' however the IAT sensor shows pretty much the same 103-103.5deg on startup, warms up and takes off dramatically. Within 5 minutes it goes up fast to like 110-115 whenever idleing at stop lights it will hit 120 easy, whenever stopping at a drive thru(3-5minutes) the IAT temperature will read up to 30deg over outside temperature, even 32-35deg over if u get stuck in traffic for 7, 8 minutes, then you speed up to 60 and hold there, it will take 2-3 minutes to get the IAT sensor reading to match outside temperature again.....these underhood temperatures are crazy, I came from a NA Camaro, and I never say IAT over 10deg over outside temp.
All this is expected though, with turbo's underhood temp is extreme for sure. Point of all this is, I'm really starting to feel the need for the CP-E CAI over the Cobb SRI. Dynos mean nothing compared to street numbers, on the street you sit at stoplights, stuck in traffic, and then when u get going you may have to drive to 5 minutes to get that IAT temperature back down, forget getting stuck in the pit at the track, here in Oklahoma you can get stuck in the pit wating on a track cleaning etc, even if you turn your s*** off as much as possible that heatsoak adds up fast. So its hard to believe those Cobb dyno numbers vs. sitting at the light with heatsoak out the ass.....
Can anyone else verify these numbers?
