F ForceFed Member : Trailblazer SS AWD ....Still a Mazda Junkie Though. May 3, 2011 #2 YOu should note this is a non P5 2.0L valve COver. You will need the coil mounting relocation to utilize this cover.
M MSP2024 Member : 2003.5 MAZDASPEED PROTEGE May 3, 2011 #3 ForceFed said: YOu should note this is a non P5 2.0L valve COver. You will need the coil mounting relocation to utilize this cover. Click to expand... it was off a 626 i didnt think there was any difference but thanks for the heads up,where can someone get that?
F ForceFed Member : Trailblazer SS AWD ....Still a Mazda Junkie Though. May 3, 2011 #4 The difference is you dont have the mounting provisons for the coilpacks on top of the cover.....I knew it was a 626 cover, and as far as coil relocaion kits....I dunno, youll have to research it.
