Rear wiper doesn't turn off ?
Asimauve
Protege5
I've noticed this recently, my rear wiper randomly turns on or when turned on won't turn off ....
Any idea what it could be ?
My guess would be an intermittent short in the switch. The first part could be a short anywhere, but the second part pretty much has to be at the switch. It sounds like there may be some bits of metal floating around on/near the contacts. I don't know if there is any way to take that stalk apart and clean it out though, so you may need to replace the whole stalk.
Doesn't the rear wiper have its own fuse? You could pull that in the mean time to keep the wiper from going off.
There is an internal switch in the wiper motor mechanism.
The motor needs to be powered until the blade is at rest position.
There maybe a problem with that switch or connection.
