I think I figured this out the other day by accident. On the belt, there's two 'hooks' that will connect to two of the latches that come up through the seat. One has a regular seat belt button on it, the other just has a slot. On the belt, one of the hooks is at the end of the belt, the other can slide along it. The one that slides is supposed to go into latch with the slot in it, and leave it there. The other one goes into the other latch, when you sit in the seat. Basicly, there's two latches for the person sitting in the middle seat. The one on the left (as you're sitting in it) has the slot in it and should be connected pretty much all the time. The one on the right is the one you undo to get in and out.
At least, this is how I remember it. I could have which hook goes into which latch backwards.
