I'd been meaning to post about running with just the rear AWR mount, so here's the chance...
History - I think I had one of the first sets of mounts from Tony to go on my '00 ES.
I put both of the mounts in at the same time - the rear I did by dropping the sub-frame (three hours later...)
The responsiveness was great, but with the defroster or AC on, it was shaking the dash to death. Since the rear was so hard to do, I put the factory front back in, using some rubber from plumbing connections to fill the voids (and large washers on either side to keep the rubber in)
The vibration went down just a bit, but you could tell the engine was moving a bit more.
Fast forward about 8-10 months laster... A clicking sound developed around the front foot area - I couldn't figure it out... Until it got worse and turned into a clunk in stop and go traffic. Guess what - th rear mount had separated - the material had ripped, leaving the flat mounting surface attached to the subframe, and the rest attached to the engine. Actually, the middle bolt had the material ripped around from it.
I then put the factory rear back in (from the top this time - much easier - just a pain to get the through bolt lined up.) and the AWR front back in. Idle and AC are much better, but strangely, 5-6.5k has more vibrations. You can tell the engine is moving much more - in fact, the AEM intake will hit the brake master cylinder sometimes (it was way worse with the factory mounts.)
I haven't contacted Tony yet to show him pictures of this - I'll try to take some and post them.
Sorry the the long post - but thoght others might like more input...
Kevin M.
'00 ES
Kevin M.
'00 ES
