Blackrose said:Ok does anyone know the trick to depress the rear caliper pistons on the MZ3. i cont seem to get these damn things to go in.
Zero Cool said:I usually open the bleeder valve and use a large C-Clamp to compress the piston. this allows the fluid to escape and the piston to move easily. trying to force the fluid back up the system can damage a lot of things! especially if you have ABS brakes! The piston should go in easily, if it doesnt, something is wrong. Make sure to bleed the brakes once your done.
Zc
Blackrose said:acctually i got the drivers side one back in and i had to turn the piston untill it was all the way in. This one i can just keep turning it and it does not go any further. Even the Protege you dont depress the piston with a C-clamp there is an adjuster screew on the back of the caliper you turn untill the piston is back in place. There is no adjuster on the 3. Im not sure were i should go from here though.
Thanks
Mike
