rear caliper brake knock sound
Turbo'd
I have a P-5 w/ 200 miles on it and when I back out of the garage and stop I hear knock or tick sound, samething the first time I hit the brakes going forward, but thats the only time it knocks or ticks.... Non ABS....
Anyone else have this going on? not that I care its under warranty, just curious....
Mine does the same (I have 600mi)... more like a tick sound though... It eventually stops doing it after I ride for a bit. I have non-ABS as well... I also notice that the engine vibrate a little bit when it's idle.
I just get the tick once...if it doesn't go away I'll take it back...No big deal, but its fun to tell dealers of what they have to expect.. :)
Thanks for responding
more than likely what you're hearing is the caliper just slightly knocking against the caliper pins. We have semi-floating calipers so the caliper can slide back and forth horizontally to compensate of rotor warpage and for brake pad wear. It's nothing out of the ordinary and won't hurt a thing.
Thanks!! I was just wondering if it was common with these cars
91 T66 Turbo'd RX-7
02 P5
02 Passat turbo
98 ///Me 4-D
Similar Threads and Articles
