 - 2015 CX-5 Touring 2.5L FWD
hmmm, it also states the rear is slightly larger than the front, you'd think it'd be the other way around, other than front is ventilated and rear are solid.  (front 11.7, rear 11.9)
The rotor/brake combo they used on the 2013's are absolute and complete garbage. I had mine replaced twice in 10 months and they had the nerve to suggest it was my "bad driving".
Maybe this was your problem. Improper installation of said parts by a terrible dealer. A dealership/repair facility is only as good as the people who work in it reflecting on the brand they represent.The rotor/brake combo they used on the 2013's are absolute and complete garbage. I had mine replaced twice in 10 months and they had the nerve to suggest it was my "bad driving".
This is one of the reasons why Mazda will drive me to another make. Generally the dealers here in Ottawa are terrible at dealing with Customers and Mazda Canada was no better.
This is so much BS. There is nothing wrong with the rotors or brakes.
No it's not and yes there is..something very very wrong...I started this thread with the problem at 15k and here I sit at 31K with the exact same issue...after getting a complete replacement of rotors/pads the first time around they are completely shot in the ass again, fronts are fine...this needs a recall asap...
Most likely someone is lightly riding the brake pedal, the E-brake is not fully disengaging or they are not properly lubed.
Good luck.
I've been saying for 2 years. My post #19 of this thread shows my less than 1000 mile brakes didn't have much lube on it, or inside the caliper body pin holes. And the grease was a dry solid. It's very easy to add some Syl-Glide or silicone brake lube of choice to these pins. 24,000 miles later and all my pads look nearly new.Both rear pads and rotors went bad at 48k (2013 model). I am very gentle on breaks. After getting quotes from Mazda, went to a local mechanic (2/3 price)... showed me that calipers were not properly lubed...both rear and front. Front had life for about 2-3 months. Got both rear and front pad/rotors replaced for about 700 with two complementary oil change and tire rotation.
Sent from my Nexus 5 using Tapatalk
When I painted my front calipers I removed the pins to separate the caliper from the bracket. I was astonished to see very little grease in the holes and on the calipers pins themselves(less than 1000 miles). I've inspected brakes on new cars before (pre 2010) and remember seeing more grease from other manufacturers. Is Mazda being stingy with their lube?? Do they have a bad brake system factory worker?! I'd suggest lubing all metal-to-metal contacts with Sylglide on all these brake systems and making sure the braking system has no unwanted stiction. That being said, newer cars these days DO have more rear brake bias than older cars due to TCS/ABS control systems. But 15,000 is way too premature to be considered normal.
Is it just the rear, or is it all the calipers? First the tire wear issue and now this... I am concerned.
