chrisandjackiep
Should the rear air on the 08 5 be blowing only cold air. We can run the heat and it be nice and hot. When we turn on the rear air it will only blow out cold air. The manual say it should work in conjunction with the front so it should be hot. Is this correct. Should I call the dealer.
