mayavision
- Mazda 6 S Grand Touring
Recently I ran over a raccoon (Unfortunately, I swerved to avoid it as it ran across the street to the right, assuming it would keep going I swerved slightly left to avoid oncoming traffic and the raccoon stopped causing my right side of the car to run over it)
MY splash guard for the right and left wheels as well as the front under-body shield came off. With that a Cable Ripped.
Immediately my ABS, SMC, & Traction Control Instrument Panel Lights came on.
I checked under the car on all sides and noticed a wire was Ripped and missing the remainder part. I also noticed a Sensor Plug was standing alone without anything plugged into it. On the Driver side I see the same sensor/plug plugged into a wire leading into the wiring harness/fog assembly.
Anyways, I thought I ripped the ABS Wheel Speed Sensor Wire on the right front side.
Today I took it to a technician to replace this Wire (As I ordered it from Rock Auto) HOWEVER, it turns out the ABS Wheel Speed Sensor wire is fine and intact, what ripped was the wire that leads from the Wiring Harness TO the ABS WHeel Speed Sensor PLug.
I have been searching EVERYWHERE ONLINE and I can't find it for this car. For other cars I find Wiring Harness Piggybacks but I can't find anything for my 2009 Mazda 6.
THe dealer wants to charge me $150 just for diagnosing the vehicle and repairs on top of that. They may even suggest replacing entire wiring harness. That would suck. What can I do? What do you recommend? Someone willing to help?
Look at these pics:
Look at these pics:
