Radio stays on when ignition is turned off
does it happen even after you have removed the inverter? if so have you tried the 2nd 12v aux power in the arm rest compartment?
Could be drawing too much power away from the radio when using the one below the radio (must be connected into the radios wiring.)
Or even hard wire the inverter to bypass all the other wiring.
Im going to remove it when I leave for work and see what happens. The problem went away for them when they removed it. Im guessing its because I ran it off the front one. The rear one could be on a separate circuit.
