Radio shutting off
b e z
2009 black mica speed 3
Ok so il start off with the problem, I was merging into freeway today and when I turned my head back around I saw a quick flash of idiot lights on the dash but I couldn't make out what they were. I continued home and I turned on my turn signal to get off the exit, then my radio just shut off and came back on, along with that I had that quick flash of lights. This just happened today for the first time. I have had a boost gauge installed since Xmas which is tapped into some acc power here the dsc button is.
Other than that I don't think I've messed with any other wires. I have had my car out of balance and had a slight wobble for a month or two, not sure if that is shaking or running some wire. So any help with this issue would be appreciated, I will take apart the dash this weekend to check out wires and investigate.
ive had the issue of my radio just all of a sudden glitching out and resetting. I dont know why though. I kave a Kenwood DDx319 that i wired using the correct plug. Any help?
Mine doesnt reset, Im assuming by reset you mean it resets your set stations and other settings like bass, treble etc. Mine just cuts off for a sec and then back on, but hasnt happened since I posted this so I have no clue.
