B BassOverflow Member Nov 10, 2006 #1 Hey guys, what's the easiest way to remove the stock radio from an '02 P5?
J jadonP5 Member : 02 P5 22V Nov 10, 2006 #2 http://www.mazdas247.com/forum/showthread.php?t=123651143&highlight=radio+removal
B BassOverflow Member Nov 10, 2006 #3 I read that thread, but I was unsure about where to put the pullers. Unlike the old Ford radios, this doesn't have the holes on the face of the radio. jadonP5 said: http://www.mazdas247.com/forum/showthread.php?t=123651143&highlight=radio+removal Click to expand...
A altspace Member Contributor : 1990 RX-7 Turbo II Nov 10, 2006 #4 The holes are under the side plastic tab covers. They pop right out.
B BassOverflow Member Nov 10, 2006 #6 I got it, thanks for the tips. Any suggestions as to where to run the power cable? I've got 4 gauge wire that I'm going to use.
J jadonP5 Member : 02 P5 22V Nov 10, 2006 #7 power through the firewall down the driver's side, signal down the passenger side or center console. there is a grommet above the clutch pedal (or where it would be if you are auto) that you can poke a hole though with a scissors or screwdriver.
