GHOSTWHISPER
damn i think mine is still under warranty, i have wanted a excuse to by a valentine one, i will send mine in and give it to my GF
Yeah i just think it needs some fixing but i do want a v1 really bad
I was having the same problem with my escort 8500 and i found on an acura forum that it was interference with the engine. The sheilding around the lazer sensor is clipped on and it sometimes comes loose. All you have to do it open it up and re-secure it. Since I did it I haven't had a problem.
The lazer sheild is a long rectangle structure under the horn shaped structure for the radar sensors. All you have to do is pinch the corners together, make sure all the mounting clips are nice and tight and your good to go.
Good Luck
