R-r Racing Udp: Excellent!
PR5Matt
I just installed it and I am impressed with the quality. The engine revs better now. Don't know aobut the power increase, but it sure feels better. Smoother too...
JCell said:
is it similar to the UR pulley?
did u need new belts?
Basically the same, and yes you need new belts. Installed mine yesterday, talk about a weight reduction over the stock pulley! I bet it's about 6lbs lighter. Easiest mod next to an intake!
You're saying it's easy?
Well if it is be so kind and please write a how to : ) hehe
but glad to hear you like it...
which belts do you need? - did it come with them?- we need details man - don't tease us!!!! (crazy)
We took pictures having the idea of a how to in mind. I'm waiting for authorization to write it:)
RR-Racing.com said:
2.0L Gates Belt Part Numbers:
belt 1: 040355
belt 2: 050450 or 050446
If you need to buy a different brand belt, its really easy to cross reference it.
The first 3 numbers denote the number of ribs on the belt, so "040" means its a 4 rib belt.
The last three numbers denote the length of the belt.
Most belt manufactures such as Dayco, Gates, Goodyear use the same numbering system.
Rafi
No it didn't come with them, but they're pretty cheap. And the smaller belt fits, no problem(050446).
You don't need authorization to write it. I'v written two. Just write it then post it and ask someone to move it.
there really is no need for a how to....once u get down there, it's all pretty self explanatory
1-Remove passanger wheel
2-remove plastic covers
3-get an impact socket of 13/16 (it's a perfect fit on mine)
4-loosen bolt by applying 130 pounds of pressure...having buddy put car in gear and applying barkes
5-loosen belts
6-remove pulley and replace with new pulley
7-reinstall everything
DiS did a great write up for me when i installed mine....click here....
it took me and a friend about 3 hours to do it....but now we know how to loosen the belts, we could do it in 30 minutes
hope it helps
5-loosen belts
DiS did a great write up for me when i installed mine....click here ....
hope it helps
That write-up IS awesome. The only thing it's lacking is PICTURES, for the extra paranoid like myself...
twilightprotege said:
yeah if you want to post a how-to, post here and i'll move it for you.
Remove the lower engine cover on the passenger side
Then loosen the belt tensioner on the power steering pump
Next lossen the upper bracket bolt on the PS pump
Crawl under and loosen the lower bracket bolt on the PS pump
Shove in and remove belt
While underneath loosen the lower alt. bolt
Move up top and remove the bolts for the cruise control vacuum canister/control. Move it to the side
Loosen the tensioner on the alt. and lossen the upper bracket bolt
Next, take an impact wrench and a 21mm socket and remove the crank pulley
Installation is the reverse of removal
(For the brackets etc. you will need 10mm, 14mm, and 12-13mm sockets and wrenches)
post the complete how to as a new topic too. that way you'll get the credit for it in the how-to section
For some reason I am not allowed to post a thread there.
