2006 MAZDASPEED 6, Sport model. 81k miles. $15,900. Over 300HP. ALL WHEEL DRIVE. 2.3L DISI Turbo. 4 cylinder. I am the 2nd owner or this vehicle. The car is in perfect condition inside and out. It is as nice and clean as the day I bought it. The vehicle has 81,7xx miles. Most are highway miles with me going to and from work. The motor is in great shape. I was compression tested 5k miles ago and it had 192psi in all 4 cylinders. It has had synthetic oil since 30k miles. The transmission, differential, and transfer case fluid has been changed yearly with synthetic fluid. It has AMSOIL front to rear. The turbo is in great shape and does not smoke. Power steering and brake fluid was replaced at 60k miles. Spark plugs are changed every 15k with denso ITV-22's. The clutch was replaced at 47k miles due to the clutch TSB. Clutch works flawless with no slipping. Shifts smooth. Tires were replaced at 70k miles with Nitto Neo Gen 245/40/18's. The wheels are Tenzo Type-M 18 x 8. Performance parts: CP-E Nano short ram intake. K&N filter. Corksport 3" downpipe. Corksport 3" catted midpipe. CP-E Single 3" resonated cat-back exhaust. PTP intake manifold spacer. Throttle body coolant bypass. EGR Delete. SM Oil Catch Can. Autoexe strut bar. Tein lowering springs. SPC adjustable ball joints. HAWK brake pads. TWM Stage 2 Short throw shifter. Desert Eagle shift knob. TWM short shift boot. Prosport premium series boost gauge. Custom vent gauge pod. Audio: Metra dash kit. JVC Arsenal head unit. JL audio door speakers. 400watt 4-channel Rockford Fosgate amp. Exterior: 35% tint front & rear. Autoexe front badgeless grill. Smoked euro turn signals. 6000k Apexcone low beams. PIAA 7000k high beams. Smoked tail lights. Black rear M . Smoked 3rd break light. Stubby antenna. Custom side mount front license plate. I hate to get rid of this car. The car has never given me any problems. Please pm me if you have any questions or need pictures.
Here are a few shots I took of the car today. I didn't have time to clean it since there is about 40mph winds here. Not the best shots but these will do for now.
