Does anyone know what the mm or size of the upper rad hose is, I want to order the prosport water temp radiator adaptor, but I just don't know which one to order is it the 28mm, 30mm or the 32mm.....
Get ahold of josuem6wagon, can be found in Ohio section, his sn is something like that. I bought his set up with the adaptor. He may know which one you need
IIRC I'm pretty sure the 30mm is the one you want. I purchased a 30mm mishimoto adaptor but haven't had a chance to use it yet. I do know that one side of the hose is bigger than the other. I have the hose size on a notepad on my computer. Problem is I'm not at my computer.
