MazdaSpeeder
- Protege5 (5-spd)
I'm looking at a great impact wrench that would be perfect for working on my rust-riddled P5. The problem is, I'm trying to figure out the best compressor to go with it. It has a working torque of 320 ft/lbs and an average air use of 4.9 CFM. Here's my conundrum...I can't break the bank on a compressor, and getting one that is a 240v is also not an option. So that leaves me with 120v options that really don't make much more than about 2.5hp, and the best I have seen as far as airflow is 4.5 CFM at 90 PSI.
If I bought a compressor like the one above, would it be enough to give me the 100-200 ft/lbs I would need to do work on my car? I realize that compressors (especially cheap ones) can have inaccurate hp and CFM ratings. I really just need enough torque to break loose suspension bolts, exhaust bolts, maybe the occasional wheel hub nut. Would a cheap compressor flowing 4ish CFM at 90 PSI give me that?
