Hey guys, about to do a rear shock install on the 09 ms3. On the Koni yellow, does 2 nuts go on the end of each shock shock? Kinda confused how this works. Thanks
no nuts should go on the shaft... the only nuts i have on the rear of my konis is the lower eye bolt ( connects to the lower arm) and 2 nuts at the top for the top ( bolted to the top hat)
the only nuts i have on the rear of my konis is the lower eye bolt ( connects to the lower arm) and 2 nuts at the top for the top ( bolted to the top hat) there is a nut that bolts the top hat to the shaft, idk why there is four pictured.
