Sometimes, when using heat and/or AC, after turning off the air vents while driving, air flow still continues. It seems to not occur when recirculation is on. Dealer indicates that this is normal in CX-9. Can anyone confirm this??
yeah, if you have recirc OFF, and you are moving, air can still flow through the open air intake through the vents. perfectly normal. and like you noticed, if you turn recirc back on the air intake will close and the breeze stops.
