Currently I am using a speaker level->RCA converter to convert the leads going to the stock sub into one mono channel then to a PPI 200x2 RMS amp/ 2 rockford s1 subs. Everything works as expected but I do not feel that the subs are responding to low frequencies very well. Is the stock bose sub crossed over on the low end as well as the high end? I mean does it have a crossover on the lowend bumping it up to say 50hz and then a high end crossover killing the highs like normal as well?
Is this the recommended method to do this or is there a better way? It seems the lineout converter is also killing alot of the gain, these subs are not hitting near as hard as the should with the RMS wattage I am putting to them, and if I crank up the lineout convertor near 100% it starts distorting fast. All wiring used is high quality and dedicated 8ga power to the amp, and the amp/subs/sealed box sound amazing when plugged directly up to other equipment(alpine crossover+ipod).
Any advice without replacing the stock HU?
