Man, it seems like everyone is having fuel cut problems with their chips.. I have only experienced fuel cut on several occassions. And those times I was running with the 1. boost controller on (green light on) 2. and on Map A (button in same position as the green lit button. Ensure that you have the ECU switch in the on (o pushed down). One other note also, I don't know if it really matters, but I was told to never change the boost settings while the car was on ( but it could be a lie, either way, I still shut the engine off )
I have only hit fuel cut on days when it was atleast 30 degrees or below. And I have only had it happen when in 4th or 5th gear trying to do a hard excelleration ( make a pass or something ).
I can't say whether or not the chip is holding boost or not. I have yet to install my guages. But i will say this, it doenst feel like it's holding boost. It's either not holding or there is a leak in my plastic piping. Good luck man. Hope this helps..
