question for linux racer
LaZaBLuEMp3
RSX type s
my friend has an IS300 and he told me that u posted that u were beatin by an IS. im assuming this is true but my friend bullsh*ts alot and he said the IS was stock. I really hope not so how bout ur info o this
even if he had been beat it doesn't matter the is is pretty quick, and now his car is turbo so i dont think any stock is will be able to beat him now... turbo
The IS 300 run with Linux was with the turbo but not at full 8 PSI only 6 and its not completely tuned yet. He cought it then the guy turned off the highway if memeory serves, he posted it on an IS web forum. Go to flamewares under the compression thread and you'll find the link.
By the way i run the same turbo at 8 PSI and I would just shame an IS300.
I would have killed him side by side if I wasn't playin catch up. He wanted to go above 120 MPH, which I did not want to follow. When we finally lined up, he gunned it, and so did I. Just as I started to pass him (really fast), he turns off on an exit.:wtf: LaZaBLuEMp3, you tell your friend that is :bs: I had that IS00, and he knew it!
