First find/take the pic you want. If it's off of the net, then you just
1) right-click on the pic,
2) copy the "properties" from it,
3) and paste the HTML(properties) to the place where you put your sig.(in your user cp)
One thing to not forget is to put a "
after it.
If you took your own pic, then you'll have to upload it to the internet first, then follow steps 1, 2 and 3.
better yet.....IF its a small picture that you found on the net, insted of using it right were it is...which is what eggy described...when you right click on the image use the "save image/picture as" feature and save the image to YOUR harddrive...
THEN....go to the "USER CP" on the board....there is a button labled "manager files"....click on that....this is where you can upload files such as pictures to the boards server.....there is a feature at the bottom of the page that allows you to browse your harddrive....pic the image file....then upload it to the server....
once its uploaded it will be displayed on that page....all you have to do now is highlight it...and click on COPY.....then put it in your sig using the IMG tags just like stated above....
this way....you won't ever lose the image just in case the site where you found it goes down or deletes that file for some reason.
