question about mazda 3 sport HID
i have a 04 mazda 3 sport GT
and the daytime driving light and low-beam light are using same projection light. maybe it has different voltages.
so if it has different voltages between day and night, is that ok for HID ? or it has special HID for low/ high beam together? like Bi-xneon HID?
i am noob, asking some noob question, thx for answering.
also if i want to install angel eye to my car, i only can get the angel eye rings and take the headlight apart, then install. someone said that i need to put the headlight into oven for 20 minutes at 200 F degree... it that insane? or ture?
i havent done alot of research on the hid yet, but the answer to your question about the angel eyes being in the oven, yes its true, i put angel eyes in my headlight.
hids will work just fine, you dont want bi-xenon that would be if your using it for lows and highs, and yes with angels, what you do is put your headlight housing into oven at 200 for about 15 minutes(without the little rubber things of course) and then pry the housing apart, use silicone to apply angel eyes, then its easier to use heat gun and wok the housing back together, for extra protection you can follow it all up with some silicone around the housing(thats what i did) works great. once you get it, it will go quick
