ILSAC GF-6 will be split into two subcategories: GF-6A and GF-6B. The principal difference between the two subcategories of oils concerns viscosity grade and high temperature, high shear (HTHS) performance. The proposed ILSAC GF-6B will provide the same performance as GF-6A, but with the added aim of lower HTHS to deliver potential further fuel economy benefits. ILSAC GF-6B will be defined for 0W-16 viscosity grade oils only.
Thank you.The silver bottle is GF-6A, which seems to be the same as the GF-6 of the gold bottle. Seems like it's just newer packaging with the updated specification.
Lubricant and Fuel Additives - Lubrizol
Lubrizol’s advanced lubricant and additive technologies bring real-world results designed to improve efficiency, reduce emissions, and enhance overall asset and vehicle performance across automotive and industrial applications.360.lubrizol.com
I wasn't able to find any information in here.
Can someone explain or point me into the right direction.
What is the difference between these two type of oils.
What does IFG 3 means?
thank you.
Looks like the 5 and 7 are only made in 0w-16. That means Toyota enginesPackaging .... IFG 3 , 5, 7 = "good//better//best" lineup so to speak
https://www.idemitsulubricants.com/...es-all-new-ifg-series-of-engine?language_id=1
