question about boost pressure and boost controllers
sleeper3
2008 Mazdaspeed 3 GT
so I've noticed a lot of discrepancies when it comes to stock boost levels and our cars. I'm wondering where the computer is reading boost levels. I'm under the impression that it reads boost from the wastegate, in which case, it is reading higher boost levels than the engine is actually receiving (say the boost pressure the turbo is producing is 19 lbs. realistically, after cooling, the boost could be reduced to stock levels around 15-16 due to the cold air being much more dense). I think this effect could account for the difference in boost pressures we all seem to be experiencing. Anyone know more about this than I do?
if that is the case, it makes sense that the more efficient the air delivery is after the turbo, the higher the boost pressure will be at the intake, even though the actual boost being created by the turbo isn't changing.
It makes sense to me that if all the MS3's were reading from the wastegate, then they all would be off by, give or take, the same amount.
Because a turbo produces compressible flow, the "ideal" gas law goes out the window. It turns out that those are some pretty difficult equations to tackle to give you a 100% result.
However I can say this with certainty. The Pressure drop due to cooling actually increases the amount of charged air entering the combustion chamber. It is all about how much "mass" of air enters. By the temperature cooling and the density increasing, more mass is being moved in any given time frame. It turns out that the rate of mass moving is based on density, velocity and the cross-sectional area of the pipe that it is in. Also remember that pressure in a fluid is the same regardless of where you check the reading in said fluid. So, if the reading is coming from the WG and the WG is connected to the BPV (like the MSP is) which is then connected to the intake mani (again like the MSP is), then the pressure in all three vaccuum lines(WG, BPV, intake mani) is exactly the same.
edit: In short, cooling after the turbo with a pressure drop is more effiicient than no pressure drop and no cooling. Odds are that the WG vac line is connected to the intake manifold, therefore the pressure in/at the WG is identical to the pressure in the intake manifold. Raising the boost to equal out the pressure after cooling = zoom zoom-er... and possibly zoom boom.
The ECU does not read boost at the WG, it reads it at the MAP sensor so its post intercooler. As you pointed out, reading boost at the WG would be way off due to pressure drop, temp difference, etc.
No.
If there is flow, the pressure MUST drop along the direction of flow.
In a static system, the pressure would be the same everywhere.
icespeed: are you saying that more mass is created when air passes through the intercooler? because no. the density goes up, the pressure goes down to compensate, and the mass stays the same.
No.
Yep exactly.
icespeed, The pressure is NOT the same everywhere in a dynamic system (aka flowing). There is a pressure gradient from the turbo to the manifold with the biggest drop in pressure occuring at the intercooler due to the decrease in temperature. This has been measured many times by tuners and manufacturers by placing pressure transducers before and after the intercooler.
I read the PDF and it sounds like boost is managed mechanically. did I read that wrong? I thought the EMS controlled it.
Its both. A solenoid valve mechanically opens and closes to regulate boost but the valve's duty cycle (how many times it opens/closes per second) is controlled by the ECU.
From PDF said:
Wastegate Solenoid Valve - An electromagnetic solenoid which controls the air flow from the wastegate actuator to the turbo
inlet. This device is normally closed when no voltage is applied. When 12V direct current (DC) voltage is applied, from the
drivers in the electronic control module (ECM), to the wastegate solenoid valve, it fully opens allowing air to pass through
the device.
ECU - Also known as an ECM, PCM, EEC, EMS. The Engine Control Unit contains the processors, drivers, and logic which
is calibrated to control the boost load via wastegate solenoid duty cycle.
ok I couldn't figure out how the duty cycles and diaphragm worked together I think I get it now. kind of.
Wow, lol, I miss one day and everything goes nuts... Ok here we go:
No.
This is only true in the piping... not in the vacuum lines controlling the WG and the BPV. The vaccuum lines are connected to the intake mani and pressure drop along the length of the vac lines is minimal enough to say that all three locations retain the same readings of pressure (again inside the vac lines).
I am not saying that mass is created. The mass flow rate (dm/dt) increases. So more mass is travelling in any given time frame. As far as the density and pressure relation is concerned, the ideal gas law is only valid in non-compressible situations. It turns out that if the density goes up, the temperature must go down for the pressure to remain the same. This scenario is not true in compressible flow. It is "almost" true that the mass stays the same, however, once again the rate of mass flow changes. Because it is compressible flow, you can "potentially" have an increase in pressure and an increase in density while lowering the temperature (such as through an intercooler). I must also point out that density and pressure are directly proportional. Your statement is only correct under the following circumstance: if the density goes up, the temparture must go waaayyyy down to cause the pressure to go down.
Yep exactly.
This is only true in the piping (as you stated in regards to the turbo-intercooler system) but not in the vaccuum lines.
As far as the pressure, itself is concerned, yes it's true that the pressure is different at different locations in a dynamic system, however as dx -> 0 and da -> 0 (cross sectional area), the pressure of any given fluid is uniform, even in a dyamic system. This particular definition of "pressure" is that of an intrinsic characteristic of said fluid where each particle is exerting an outward force per area against all others as dv -> 0
here is the math: as stated in my above post, it becomes very complex with compressible flow:
dm/dt = (rho, p)(velocity, V)(Cross sectional area, A)
Note: This is the mass flow rate eqution. It says that a change in mass per unit time is equal to the density times the velocity times the cross sectional area [of the piping in this example]. In a non-compressible flow application, it is very easy to determine velocity, m-dot or the cross sectional area. However in a compressible flow application, it is much harder to do.
(Pressure, P) = [(rho, p)(gas constant, R)(Temp, T)]/(Mol mass, M) -
Note: This is the ideal gas law. It is under the assumption that dp/dt = 0 Meaning that this equation is only valid in non-compressible flow. Once Compressible flow is involved, it becomes a very tricky system. It becomes a P.D.E. where we have dP/dt = [ (dp/dt) (R) (dT/dt)] / dM. It cannot just be integrated w/ respect to time, because any one of the d( )/dt's can retain a different order of consistency, thereby allowing energy to be lost from the system.
This leads to even more complex situational considerations. We have neglected viscosity (as it is very minimal in an air situation) and we have also neglected heat transfer. In all reality, this system is not closed and therefore the conservation of energy law is also void. Because heat can be transferred outside of the system, I can say, "It is almost true that mass stays the same..." from the above response.
So, as I stated originally:
Ok, I just re-read my original post. I see where everyone is mis-understanding me. It was the statement, "Also remember that pressure in a fluid is the same regardless of where you check the reading in said fluid." I explained it above, but will do so again. This was in regards to dx and da -> 0 and under the assumption that air is not flowing through the vaccuum lines until the breaching point of the WGA spring, thereby creating a "local" static system, where the WGA, BPV and Intake Mani all have the same pressure. So, Abaddon and Jays07MS3, you are both correct in your statements, but not in regards to the intial values I assumed.
"I am not saying that mass is created. The mass flow rate (dm/dt) increases. So more mass is travelling in any given time frame. As far as the density and pressure relation is concerned, the ideal gas law is only valid in non-compressible situations. It turns out that if the density goes up, the temperature must go down for the pressure to remain the same. This scenario is not true in compressible flow. It is "almost" true that the mass stays the same, however, once again the rate of mass flow changes. Because it is compressible flow, you can "potentially" have an increase in pressure and an increase in density while lowering the temperature (such as through an intercooler). I must also point out that density and pressure are directly proportional. Your statement is only correct under the following circumstance: if the density goes up, the temparture must go waaayyyy down to cause the pressure to go down."
so you're saying that a larger mass of air is flowing through the output of the intercooler than the input of the intercooler? I'm sure you don't mean that, as it is not possible. the mass of air has to be the same unless the intercooler is somehow producing more mass, which is impossible.
mass per time is different than what you're taking it as. it is not "adding" mass. i'm going to come back and edit this post with a good example, i just need to think of one... bear with me for a few minutes.
edit:
ok, here's a good example: Suppose we have a balloon. We blow it up so it is the size of a basketball. Let's say it weighs one pound (this is a big number, but only used for this example). Then we take it and put it in ice. The air inside the balloon condenses and the balloon becomes the size of a baseball. It still weighs a pound. Now, let's suppose that we have a pipe that can fit the basketball sized balloons through. and one by one we push them through. Let's say it takes 1 min to push a balloon through. Therefore we are moving 1lb/min of mass. Now, let's take 20 balloons and put them in ice. Those 20 balloons are now the size of baseballs and, coincedentally, we can fit more baseballs in the pipe at a time. So now we can move all 20 balloons the same distance in the same time. We are now moving 20lbs/min. No mass was added to the system. But mass flow has been increased.
Does this make sense?
lol! 1st post on here and it's cuz your brain's about to explode! lol
Well welcome, atleast! lol
/threadjack
He thinks he has a headache. I'm trying to remember classes I took thirty years (and countless bottles of single barrel kentucky bourbon) ago. God I need a drink!
One thing that bothers me in the logic being developed here is the frequent reference to fluid dynamics, when we are dealing with a compressible gas system.
One thought that might clear up the problem some are having with the greater mass at the outlet is to remember that there are three ways to change the pressure of a gas.
You can change the temperature, which changes how "active" the molecules are. Hotter, more active molecules exert more pressure on their container.
You can add molecules to the system. More molecules of the same activity level (temperature) exert more pressure than less molecules.
You can make the container smaller. The same amount of molecules at the same activity level will exert more pressure stuffed into a smaller container.
This means that there are more air molecules per square inch at the end of the intercooler than at the beginning.
The reason it is denser at the outlet than at the inlet is that, as we all know, cold air is denser than hot air, and as the compressed air travels through the intercooler, by design, the intercooler is taking heat away from it, which makes it denser. The turbo keeps the system pressurized, and even though the pressure is essentially the same all through the intercooler, the reason is because the hot, active, but less dense molecules at the inlet create as much pressure as the colder, less active, denser number of molecules at the end of the intercooler.
I hope that helped.
I hope that helped.
lol, much better said than me!
Sorry I went overboard, but I just took Fundamentals of A.E. last semester so we did all sorts of compressible/non-compressible, laminar/turbulent and the like. It is all burned in my brain!
