psyco-joe's Green Lantern build
yeah probably. doing that would probably have made doing it a whole lot easier too, trying to mask of the lip was quite annoying.
i am going to have to put some of those plans for aero on hold right now while i get some stuff sorted out. I am going to be replacing the soft top because the tear on it is getting worse.
and i still have to go through and work on maintenance. oil changes, changing the dirty coolant and stuff.
i am also considering getting the paint redone because I am tired of looking at my sun damaged trunk and rear quarter panel.
long time no update, so here is what's going on, got a nrg quick release and short hub with sparco strada wheel, fixed the slave cylinder leak. i sold the drag wheels and am now using the konig spooled/falken 615-k set up on the street. scored a used softop for $80, I am going to clean up and get the minor problems with it repaired then put it on.
