protege turbo manifold
richtq
2002 mazda protege es
i have an ebay turbo mainifold on a 2.0 mazda engine and i want to know if thats a decent manifold to put on my 02 protege es? If its not a good one i guess a stock mazdaspeed manifold will do just fine. All im gonna do is boost like 6psi thats all unless i can use a msp ecu in my es. Could i use that without modifying the wire harness? Fill me in on what i can do to that es for a little boost. I picked up a probe se with a turbo and im gonna swap the parts to my es soon. Its with an fmu setup.
I suggest you do some research. Ebay manifold may look pretty but its not going to last......not without some bracing and rewelding usually. A stock MSP manifold isn't much better, but it works and it fits. I am not sure about the MSP ecu, someone else will chime in. FMU set ups work, but they are not the safest and most tuneable option. Just search and read, knowledge is power.
ok thanks for the info on the manifold. If i dont buy the stock one i will look into yours for sure. I will stick with the fmu until i learn more about the ecu part.
