Ok so I am looking to replace all my bushings on my P5 and I was thinking (thought) that maybe the Protege Speeds have a stiffer bushings. Would make sense, right? If they did, they would most likely fit, right? Below are the parts along with the standard OEM P5 replacement part numbers:
Upper (34-012) and lower (34-0A3) Spring seat bushings Front and rear.
This Conical rubber bushing that goes under the shock boot (34-111).
Front (34-156) and Rear (28-102) stabilizer bar bushings.
All three rack and pinion bushings (32-123) and (32-124)
I am debating whether or not I should buy the whole lower control arm or not. I want to take off the hub and see if the ball joint is all loosy-goosy if it is, then I have no choice but to replace it.
I have 135,000 miles on my beast, what do you guys think? Thanks.
