Prosport Electrical Gauge Issue
Landjet
Mazdaspeed 3
Just installed a Prosport Elec. boost gauge last week. Everything was fine until this morning-the gauge started showing 4psi with just the ignition on. Now shows 4 addtional lbs of boost under WOT. I unistalled and reinstalled everything (made sure all connections were sound). After searching, I see there are a lot of problems with this company's gauges. I guess I should have ponied up the coins for a decent gauge..
I've had mine for 6+ months and never had a problem. Who's having problems with these?
I would reach out to them and see if they can help you. They do stand behind their product, so I'm sure they will point you in the right direction...
Several people on this board have indicated they were seeing an issue with the gauge (prosport) showing vacuum with just ignition on. The gauge is so cheap ~75 that it's almost not worth the hassel to screw with an exchange-especially if I end up having to pull it out again.
I think it is hit or miss with Prosport. Mine is dead on, but others have had some problems. The good thing is that their customer service is AWESOME! Hope it works out for ya.
just contact prosport, they'll have you mail your sender to them and they'll send a new one.
