Proper bushings and grease for use with clunk fix
stftk14
Title says it all - could anyone please tell me the name/size or model # of the bushings that should be used with the axr clunk fix kit? Also could you please recommend the best grease to use?
the AXR bracket comes with special greasable bushings. might try contacting AXR to see if you can order the bushings separately. other wise you can get regular 20mm rear sway bushing from SU. they should fit. just measure the width of the stock bracket compared to the part of the AXR bracket the actually goes over the exterior of the bushing. the AXR bracket/bushings also come with energy teflon grease. you can order it here:
http://www.energysuspensionparts.com/Energy-Suspension-Formula-5-Prelube-Bushing-Lube.asp
Thanks! So the formula 5 prelube is the best option or should I go with marine grease or amsoil synthetic water resistant? Is there a consensus best grease?
only one i've used so far is the formula 5. it works well, but doesn't seem like anything too special. i'm sure there are others that perform just as well...
