Where did you get the automotive grade carpet padding?altspace said:Also, plain foam will suck up moisture and create mold over time. That is why I used automotive grade carpet padding.
San Jose? You should come out to a meet sometime. Show off that acoustic foamnovAKs47 said:The acoustic foam REEKS for about two weeks after you pull it out of the box it shipped in. Once the smell is gone though, it's gone for good. You might still smell it for a while whenever you pop the trunk though. I got it from partsexpress.com. I got 3 sheets of it, which was more than enough for the trunk. And foam absorbing moisture? Perhaps if there's a broken interior seal or something, or you live in a truly cold area.(as in snow) Here in Cali(SJ), the coldest it gets here is around 40F.
Kooldino said:Just curious...all that asphalt stuff you pulled out...what did it weigh in total?
altspace said:Pulled out? I added everything to what was already stock.
Prodigy said:I think he was talking about the gooey black stuff that's under the plastic in the doors..
SenorCorwin said:Can i get a lil more detailed instructions? Id like to do this in the back area for my new set up and in the front door panels... but i want to do it right.
altspace said:Dynamat is indeed a rip off. That's why I used eDead and it tightens up everything. Especially the doors. If you look at my photos at the begining of my post you'll see that the car has a good amount of this type of product lining the floor from the factory.
AODfan said:i used Damplifier from Second Skin Audio, good stuff got a 40% discount off + free shipping since i was a memeber of some audio forum at the time, ill find out what it was later. but i got like 100sq ft for like $160(i think, its been a yr) should look into that, its not asphault based either.
got wake? said:second skin is not butyl based, that much i do know. dynamat extreme and the BXT are the only 2 made of butyl that are on the market. plus the guy that runs second skin is a complete asshole. after a fellow competitor died, he made jokes about it(321fu)
