I had an unsettling experience after plugging recently received Snapshot device into my 14 6's OBD port.
When connected, the dashboard lit up like a Christmas tree w/ every warning indicator, and the car wouldn't start! I immediately removed Snapshot from OBD port; car then started (thank god) but engine indicator light remained lit. Drove around the block...nothing seemed amiss, even while engine light stayed on.
I connected OBDII scanner (with vehicle off) - DTCs U0100, U0121, & P0000 were showing, which after investigating seem to refer to PCM communication issues. My OBD scanner has ability "Erase" DTCs being thrown, but I DID NOT clear them. After a 2nd scan to confirm these DTCs (and hoping no add'l), I unplugged scan tool & started her up. Started fine, and engine light is off w/o manually clearing codes using scan tool. I will be taking car to dealer to look things over - fingers crossed that the cheap-o, POS Snapshot didn't fry any electrical components.
For people considering Snapshot, I'd steer clear of the device. Especially after reading up and learning there have been many cases of prematurely drained batteries, or worse... For the record, I used snapshot in my previous car ('01 Mits) without issue.
Has anyone else have similar experience using snapshot on 2014 6??
