PRofec B-spec VS. T.V.V.C
murdock_
EHH im sort of a nub but im trying to learn about boost controllers and was looking for a more professional opinion... ive read about two GReddy products in the topic and was curious to see what would be better for me... im looking for a extra boost when I need/want it... if u could give me ur opinion with pros/cons to both it would be greatly appreciated! thanks in advance!
-Jay
PS- I searched the forum for info and found little that i was looking for. THanks again!
tvvc
pros:
more economic
easy to use
easy to install
minimal boost spike
cons:
can only have 1 boost level set
Profrc B
pros:
looks cool
has 2 boost levels
holds boost well
relatively easy to install
cons:
more expensive
If money is no object get the profec B
but would it be right to compare the 2??? i mean one is electronic and programable, the other is a manual, twist type. i would compare the TVVC to that 2 level TurboXS controler. and the profec bspec to another electronic one. that TurboXS controler is tyte. it comes with a red, shielded high boost switch. makes it look like a weapon arming switch. mount it on the headliner and that would look tyte. just my 2 cents
