plarsen111
- 2007 Mazda5
Bought '07 Mazda5 yesterday. My mechanic wants me to do a $250 transmission fluid change. Is this necessary/recommended?
Thanks,
Phil
Thanks,
Phil
Since I do my own oil changes every 5k, I also drain the a/t pan and refill at the same time. ≤ 3 quarts is about what the pan holds.
Definitely NOT Mazda M-V! I am referring to the typical upper tier boutique vendors like Amsoil, Royal Purple, Redline, etc.. They range from in the low to mid $10s per bottle.By quality, do you mean Mazda M-V ?...
...I think I'll stick with my fluid draining interval.
I consider transmissions to fall under the category of "specialist." I also seek out specialists for A/C, suspension, electrical, and tires too. Sure there are lots of capable all-round mechanics, but only the really good ones will tell you when they don't feel comfortable working on something themselves.
