My bad I didn't see your post. I painted my stock mani with some 2000* spray paint from autozone after I had it welded up. It's made for exhaust manifolds/headers. You are supposed to bake it at around 250 then 400 then 600 then put it on the car and let it run for a bit then it's supposed to be 'cured'. It's held up fine so far.
Did you grind off whatever that crap is on the flange of the steedspeed?
FTC is installed as well as an ACT clutch set- currently running 20psi. Think I'm going to run 22psi and leave it at that. I had originally planned on 24psi.
I put the new clutch on in my driveway... With the most basic tools... It sucked, but I had it done in about 6 hours by myself.
Picked up a new spicy front bumper to install, too. Mine had been repainted by the previous owner and was done poorly and matched even worse.
This is my "apartment garage" as my girlfriend calls it. lol Not being able to do big jobs in my shop now forces me to do work at home.
