Ok, I have tried searching the forum, hoping someone might have encountered this problem, but found nothing.
I have a 03 P5 with OEM alarm. The alarm works fine, but sometimes it will not unlock the hatch and the 3 other doors (passenger and the 2 rear). Likewise, it may not lock those 3 doors or the hatch when alarm is engaged by the remote and the LED is blinking about every second, which is normal.
I also have tried to lock and unlock the doors while driving using the lock button on the driver side, and sometimes, the same problem occur. The only door that always work is the driver door. Does anybody have any idea what is going on? If I play with the alarm long enough or by turning on the car and put into gear and out it back in park and turn off the car, all the locks work again usually. Help please...
