Power cuts at ignition switch
KptClutch
03 SpicyMSP
Hey all,
So I'm having a strange power issue. It's happened twice in the passed two days.
I'll jump in, pop the key in the ignition, and turn it over. Power seems to drop real low whenever I turn it to the on position. Gauges dim, no mileage shown in the cluster, etc.
I removed the negative battery cable last night and did a reset on the e u, recast ended the cables, and she fired right up. She's doing it again today, but no luck with the ecu reset.
I do bar a bit of corrosion on the battery terminals that'll be cleaned off shortly. I'm feeling like it may be the ignition switch if that doesn't resolve the issue.
Anyone else have any ideas?
put some baking soda in a cup of water and dip the terminals in that to clean them and try it again (not at the same time, otherwise you will see sparks!) if that doesnt solve it than you may have something draining all the power. do you have a voltmeter by an chance?
