Try this..Thanks for the heads up...Can you link me to an example?
Yeah it's a known issue we're still working on...Thanks for the heads up though, good news is I may have found a solution. In the meantime, you could try taking pics in a different orientation if that helps.Is there any way to rotate images we upload? A few of the pictures I tried go upside down when viewing full size.
Cool.@JazzySP20 @Avoidin Deer Update...We've installed an Image Optimizer add-on that is currently running (it will take a while to get through all the images on the site)...It should reduce the size of images without impacting quality (too much). This should reduce image and page loading times.
Still goes upside down for me when I try to attach to a post. Picture is saved right side up on my pc.@bwalt I believe we may have fixed the pic orientation issue...Can you confirm?
Excellent point about monitor resolutions and yes it should reduce the storage load as well...Have you noticed any difference yet?Cool.
I can't imagine anyone noticing a quality issue, since monitor resolution is the constricting factor. This should reduce forum storage requirements as well.
Thanks!
Thanks for the update...Can you link me to the exact post with the pic in question. We tested the fix and it seemed to work.Still goes upside down for me when I try to attach to a post. Picture is saved right side up on my pc.
I just went to the Random Picture Thread and the pics actually all load for me!!!Excellent point about monitor resolutions and yes it should reduce the storage load as well...Have you noticed any difference yet?
Awesome, thanks for the update!I just went to the Random Picture Thread and the pics actually all load for me!!!
Much, much better!!!
Last pic at bottom of post #37.. If you click on it to enlarge the orientation changes. This happened with other pictures that I didn't bother posting.Thanks for the update...Can you link me to the exact post with the pic in question. We tested the fix and it seemed to work.
If you're talking about the one with the red valve cover & vacuum gauge, it works fine for me.Last pic at bottom of post #37.. If you click on it to enlarge the orientation changes. This happened with other pictures that I didn't bother posting.
Thanks...Previously posted pics may still be affected though so future pics should orient correctly. That said, I've noticed when not logged-in, that image orients correctly but when viewing as a Member (with my account), it does not (when enlarged)...Investigating.Last pic at bottom of post #37.. If you click on it to enlarge the orientation changes. This happened with other pictures that I didn't bother posting.
Yes, pages loading a little bit faster now. The images are still very (very) good quality. Too good even.@JazzySP20 Can you confirm if you notice a difference?
