p5sundevil said:ok again u are not reading everything, it was not 30whp just from the regrind, and im not talking about grinding to Jspec specs, I am talking about a little more aggressive that will still keep the power band broad and not push it all the way up. Also inclided in the 33whp gain was a good port and polish job on the heads which does lossen alot of hp on some cars.
Cams and Headwork =30hp = :bs:
p5sundevil said:
why would i show you how to bore a head, i read that that tea did it and had no reason to disbelieve them since the article was in Sportcompactcar and their specs have all been checked by the SCCA. And yes their particular car was 210whp with a redline of 8 grand so it was a 5-7grand engine, but that also enables them to lossen more power in the future still without going forced induction, as race engines should be.
I'm saying show me a GUY who spent LESS Than it'd cost to turbo the car for the same results. Show me a guy who spent less than $5000 for 50whp.
p5sundevil said:
the only reason I believe NA is safer than boost is cause of the basic funtions of a turbo, it forces pressure and heat back into the engine. NA doesnt do this, it actually increase flow and increase the cool air going into the system. yes an intercooler setup helps this but Im talking about those starter systems of 4-5psi that run with an FMIC.
You are comparing apples to oranges. a 4-5psi turbo on a Protege = about 150whp. Those kits can be had for a couple thousand dollars. Show me a 150whp Protege with $2000 in Naturally Aspirated mods. Anytime you create more power, you create more heat.
p5sundevil said:
also to make sure you are getting these maximum gains that I am so unrealistically talking about your engine has to be tuned very nicely to make suure you ahve everything running to its full potential, better pistons with a slightly raised compression can help this but that is only a small part of the tuning.
And is it 'free' to tune? What is there to tune?
p5sundevil said:I dont mind if u dont believe me, I was trying to help the person that originally asked the question in the first post to give him an idea of what some people are doing NA. and what is possible even if some dont Think so. skeptic or asshoel its not what u say its how u say it, but im tired and have a headache thats been around for 5 days so I might be an asshole too right now.
Just present accurate information. In order for this guy to get his Protege to even 150whp he'd need at least several thousand dollars in cams, port/polish work, Flow Bench time, labor, ECU work, New, higher compression pistons, valve springs, and fuel upgrades. Several thousands of dollars.
Or, he can buy a simple off-the-shelf turbo system.
See?
