Popping noises when turning ans excellerating
Circle9
2007 Mazdaspeed3
I think the noise may have to do with the suspension, so I'm posting it here.
Just like the title says, I've been hearing popping noise when turning, usually at lower speeds when the turn is tighter. I sometimes will hear it when I'm excellerating as well. The noise seems to be generating from the front part of the car.
What are some parts I should examine for loose bolts or damaged metal? Could it be my front end links?
I hope all it turns out to be is the springs. I thought it may be more serious, as my stock BPV has been rubbing against the plastic venting on my hood.
