Here's the info from
http://www.redlineoil.com
MT-90
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil thats slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
SuperLight ShockProof
A unique product with the viscosity of 75W90 gear oil but lower internal friction similar to that of an ATF. Used when temperatures are not high and when the maximum power output is required such as in stock car qualifying laps.
Used in two-stroke and four-stroke motocross transmissions (often mixed in equal parts with LightWeight ShockProof Gear Oil).
Used in 80cc and 125cc shifter kart transmissions.
Used in low-power road racing transxles like Formula Vee and low-power SCCA Production classes (dog-ring type, generally not sycro application where this product can be slippery).
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
Used in two-stroke and four-stroke motocross transmissions (often mixed in equal parts with SuperLight ShockProof Gear Oil).
Used in most road-racing differentials with moderate power and dogring racing transaxles.
gear oil tech info
shockproof tech info
mtl tech info
mtl product comparison
