I am going first apologize for all of the posts about, what seems to be, the same issue. You all have helped out a lot with helping me trouble shoot this issue.
CEL came on and has these two codes, PO303 cylinder 3 misfire and PO421 I believe is the warm up cat, cat at the header.
Question is: Is the cat the same for a Protege as it is for the MP5? I am wondering because Magnaflow only lists the Protege.
Also, do you think that it would be better to just do a header and eliminate that cat, secondary cat is already gutted, if that makes a difference.
With the cylinder 3 misfire and doing all of the things mentioned on other posts, what else would cause this? I have looked into the fact that the ECM could be bad as well.
Thanks for your help in advance.
